boost control
Old May 3, 2005 | 09:24 PM
manous04's Avatar
manous04
Default boost control
how many more pounds of boost can you get out of a stock turbo before it starts damaging things
Old May 3, 2005 | 09:53 PM
OrochiDio1's Avatar
OrochiDio1
Default RE: boost control
well its depend on how rich/lean you run stock wise i wouldnt go past 15psi S1/S2 holding 18psi youll be fine the turbo is fairly small so from what people say it runs out of effeicanty at 18psi. i dont know i dont have the maps for the turbo call mistubishi and ask. i run 18psi with 20psi spike but i have s/2
Old May 4, 2005 | 01:11 AM
LilSparkPlug's Avatar
LilSparkPlug
The stock turbo doesn't run/flow well above 19psi. Hence why Stage 3 comes with an upgraded turbo to replace the factory one.
Stock I get anywhere from 11-15 depending on weather and elevation.
Old May 4, 2005 | 04:08 PM
roachnigga's Avatar
roachnigga
Well what car are you referring too?
If you talking about SRT's then the comments above i will agree with.
