Headlights
Old May 9, 2005 | 08:25 PM
DodgestealthQs's Avatar
DodgestealthQs
Default Headlights
I'm thinking about buying a srt4 but the front end is smashed and it really only needs the headlight. I was wondering if just a regular neon headlight would work!
Old May 9, 2005 | 08:37 PM
PSI Chick's Avatar
PSI Chick
Default RE: Headlights
yes, they use the same lights.
Old May 10, 2005 | 01:11 AM
LilSparkPlug's Avatar
LilSparkPlug
The headlights are pretty cheap anyhow if you get them from Modern Performance, a hundred some odd bucks a pair, and really easy to replace. Just make sure the radiator supports where the lights connect to are all set and your golden . Got any pix of the car?
