picking up a srt4 hopefully wednesday
Old May 18, 2010 | 12:20 AM
rickyrod33's Avatar
rickyrod33
Default picking up a srt4 hopefully wednesday
what should i look for and ask the seller when i check it out and test drive it... its a 2005.. what are the common things that go wrong with them?? i also wanted to know whats the max psi i can run it at stock without blowing the turbo or messing anything up herd alot of different answers with the psi just want to know whats safe... really need some advice.. thanks
Old May 19, 2010 | 09:59 AM
amoeba's Avatar
amoeba
The dealer will only tell you good things. They are afterall trying to sell a car and make some money.
If you are not one who has faith in inspecting the vehicle themselves, then the dealer should allow you to take it to a mechanic for you to have it inspected for possible mechanical issues and previous accidents.
Do not depend on CarFax!
Not many things go wrong with these cars, unless they are driven hard.
Real hard, and not maintained.
Maintenace records are a bonus!
As for a visual inspection yourself, check the front wheel wells for bits of rubber stuck to it. Indicator of hard launches.
In reference to PSI, the ECU(Computer) controls the boost(13-15psi), unless mods have been done that bypass the ECU.
Enjoy the car. Keep your license. Drive carefully.
Old May 23, 2010 | 08:24 PM
rickyrod33's Avatar
rickyrod33
ok..thanks for the advice dude greatly appreciated..
