difference between 03 SRT-4 and 04 SRT-4?
Old May 13, 2005 | 12:04 AM
noeleven's Avatar
noeleven
Default difference between 03 SRT-4 and 04 SRT-4?
what makes 15hp difference for 04 SRT-4?
is it turbo? or boost?
im a noob...
please reply
thanks guys
Old May 13, 2005 | 12:47 AM
whoosh's Avatar
whoosh
Default RE: difference between 03 SRT-4 and 04 SRT-4?
bigger injectors and a quaife limited slip diff (lsd)
not sure what else, PSIchick should know lol
Old May 13, 2005 | 02:30 AM
PSI Chick's Avatar
PSI Chick
04's come with the s1 injectors and a slightly more aggressive s0 map programed in. once any of the stage kits go in though they are equal power wise.
Old May 13, 2005 | 02:37 AM
whoosh's Avatar
whoosh
^^^see knew it^^^ lol, but handling wise, the 04's and 05's are better right?
Old May 13, 2005 | 02:39 AM
PSI Chick's Avatar
PSI Chick
if you're referring to the addition of the lsd, then yes, they are a little better, but not as much as you would think. all the suspension parts are exactly the same.
