View Poll Results: A poll
Stock 11-13 Pounds
42.86%
Modified 15-17 Pounds
23.81%
Modifiied 18-19 Pounds
23.81%
Modified 20+ Pounds
9.52%
Voters: 21. You may not vote on this poll
What is your current Turbo Boost
Old May 27, 2005 | 01:35 AM
orangesrt's Avatar
orangesrt
Default RE: What is your current Turbo Boost
im stock too but i also spike at 15 psi
Old May 27, 2005 | 04:07 AM
LilSparkPlug's Avatar
LilSparkPlug
What roach****a said. If you boost too high youll be throwing partial throttle overboost codes, which are no fun to erase. Set it at 17 to be safe, until you have the supporting mods to raise it higher.
PSIChick, Rick (Kotu100) was boosting 20+ but hes got a few leaks and some busted axles right now so hes not boosting anything.
Old May 27, 2005 | 01:08 PM
PSI Chick's Avatar
PSI Chick
well i'm glad to see that i'm not alone!!! sucks about his car though, but i've been there myself. he'll be up and running again in no time!
Old May 27, 2005 | 03:49 PM
roachnigga's Avatar
roachnigga
Psi, you blew an axle as well or was it leaks....
sorry to hear about, Rick..... what happened?
Old May 28, 2005 | 03:33 AM
LilSparkPlug
His clutch has been slipping for awhile, but I guess on a hard launch he broke both the driver side and passenger side axles. He ordered just the passenger side initially and when he installed that one, realized the driver's side had kicked the bucket as well. I believe he installed the driver's side one today, in time for the meet Sunday in New York.
As for the boost leaks, Im not too sure. He had it up above 22psi I believe (I want to say 24) but had to lower it because of the leaks. It occasionally misfires too. But unlike PSI Chick he's Stage 0, which is where a few of the aforementioned problems come into play.
Old May 28, 2005 | 06:42 AM
roachnigga's Avatar
roachnigga
Ouch[:@]... glad hell be back up soon
Old May 28, 2005 | 11:54 AM
black4's Avatar
black4
only way im going over 20 psi is with stg 3.
Old May 28, 2005 | 02:34 PM
roachnigga's Avatar
roachnigga
that what happened with a weak clutch... i think
Old Jun 11, 2005 | 03:03 AM
American__Muscle's Avatar
American__Muscle
PSIchick, you can run 20+ lbs with just s3 right?
Old Jun 11, 2005 | 06:26 AM
PSI Chick's Avatar
PSI Chick
yes, i'm running 24psi. although i have a few supporting mods, and i've been hearing that people that don't have the other parts are seeing more like 20-21psi.
crystal - it's funny, i think i jinxed myself with this thread. first time out at the track with s3 and what do i do? blow my axle! this is how i ended up....
