STAGE 1 here tomorrow!!!
Old May 28, 2005 | 08:36 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: STAGE 1 here tomorrow!!!
I really like mine on the trunk lid, it looks great there. It's the only sign that anything is done to mine so it's no big deal and I just love how good it looks on the back.
[IMG]local://upfiles/193/3741866A3374481189AC3A0612535629.jpg[/IMG]
[IMG]local://upfiles/193/FEB0D86E800C4D9AB6762E7C999ABFFC.jpg[/IMG]
Old May 28, 2005 | 11:43 AM
black4's Avatar
black4
gained 20 hp he said lmao.
Old May 28, 2005 | 01:01 PM
seanie719's Avatar
seanie719
I put mine on the trunk under the SRT. Can't really go stealth with an SRT hehe so I figured I paid the money for it, why not show it off.
Old May 31, 2005 | 07:40 AM
71RoadRunner
That's pretty much the way I look at it. Unless your going to take the SRT-4 name off and remove the spoiler and replace the nose and hood with stock Neon parts and truely go stealth, then there's no point in leaving the Stage badge off to try and fool someone.
Old Jun 1, 2005 | 04:27 PM
Silverrt4's Avatar
Silverrt4
Finally got the stage 1 put in. It was def. not hard to install. The plugs don't even need to be marked top, middle, bottum before you unplug them, there is only one plug pattern for each plug. You can only plug them into the right one. What a difference that Stage1 kit is, the boost is just right there at the get go. Any one who is not going to be doing any crazy mods on their Srt-4s I suggest the stage1 kit it is much more snappy now than stock. Invest the money it is def. worth it.
Old Jun 2, 2005 | 06:17 AM
71RoadRunner
Someone was on here before saying that they put the plugs in in the wrong order frying the PCM or so they claimed, that's why I suggested labeling them. I never tried hooking them up wrong to see.
Yeah, you get about 7-8 psi now where you once had only 3 psi, it comes on quick and strong. Too bad it doesn't double the peak boost like the Mopar PCM did in my Shelby Z bringing it from the stock 7.5 psi to 13 psi. Imagine the SRT-4 at around 22 psi from just Stage 1.
Old Jun 2, 2005 | 11:08 AM
Silverrt4's Avatar
Silverrt4
Yeah it is def. impossible for a screw up. The colors on the new pcm match the stock one but the colors don't mean a damn thing, they are not even in the order of which the colors are printed. I know b/c i unhooked my and then realized that you said to tag them. I stood there looking at the pcm but that wasn't going to do anything, then i looked at the tabs on the inside of the plug sleeve, def. all different which was great.
That would be amazing about the peak boost. You were right about the Stage1 it is awesome well worth the purchase.[sm=bounceybounce.gif]
