trans slipping..
Old Sep 27, 2010 | 06:54 PM
rickyrod33's Avatar
rickyrod33
Default trans slipping..
i noticed it before but this is the worst its been.. first drive of the day i was at a stop sign and made a right in 1st gear i was steping on the gas and i started moving but then when i was steping on the gas harder i herd my engine speeding up but i wasnt going any faster then it just like broke through and started going.. this happened to me in second gear too i had to pull over a couple time... but then it went away.. does anyone know what this is? could it be that my trans is going?
Old Sep 27, 2010 | 08:13 PM
sapporo's Avatar
sapporo
forward (rear cluch )failue. or governor pressure holding 2nd gear on. put tran in manual 1st and see what it's does. if manual shift fixes, governer is skicking causing the problem. if no change then it's rebuild time
Old Sep 27, 2010 | 11:55 PM
rickyrod33's Avatar
rickyrod33
Default slipping trans...
what u mean how can i tell if it needs to be rebuilt? is it expensive?
Old Sep 28, 2010 | 12:49 AM
mxrnick's Avatar
mxrnick
first you are talking about a srt-4 right? if you are it sounds like time for a new clutch for you. if you have an sxt with an auto then i dont know autos are too complex for me.
Old Sep 28, 2010 | 12:32 PM
rickyrod33's Avatar
rickyrod33
true.. yeah its an 05 srt4 with 40,000 miles on it... first clutch... how many times did u replace ur clutch?
Old Sep 28, 2010 | 06:24 PM
mxrnick's Avatar
mxrnick
on my first srt4 that i got new i had to replace the clutch at under 10k miles, but i used to drive the **** out of it. my current srt has 68k and its on the stock clutch still, im pretty sure, i got it used at like 50k and ive seen the clutch and i know its at least a stock one im just not 100% that its the original. so moral of the story is ever clutch wears out at different times. ive heard of people that have had 120k+ miles on their stock clutch and it be ok but most of those are usually highway miles mine at almost 70k is starting to go but i drive aggressivly. i would say its your clutch but im not a 100% on that so i suggest getting a professoinal to take a look and double check.
