Installed my CAI and OCC! Check it out!
Nice. Disconnect the line at the bottom and cap both ends. It is basically a 1 lb boost leak. disconnect the intake from the crankcase vent, cap that nipple and put a breather on the crankcase.
If I put a breather on it wont it leak oil out of the breather, I thought oil leaked out there as well?
And that line at the bottom... Do I follow the line all the way back and cap it off there, and where does it come from?
Thanks
Andrew
Thanks
Andrew
Here is a shot of the way I set it up:
[IMG]local://upfiles/4404/00FB9698FE08431DA229811CEE47EFB4.jpg[/IMG]
I put a catch can in front of the breather filter, to keep it from getting soaked with oil and dripping.
On the line, I just capped the nipple, and capped the end of the line. I will pretty it up, sometime, but for now, it works like a charm.
ORIGINAL: SRT4STYLIN
Ok guys, How do you I post my pictures on here!!!
I tell ya its always something!!!
Thanks
Andrew
Thanks
Andrew
