Motor Mount Question?
Old Jun 4, 2005 | 07:54 AM
Bob96's Avatar
Bob96
Default Motor Mount Question?
I was thinking about the inserts that fit in the stock motor mount. I see the upper mount in plain sight at the top left of the engine, Where might the right side mount be located? The Mod looked simple and would be for the left side. How bout the right? Are upgrated bolts recommended?
Thanks
Old Jun 4, 2005 | 03:23 PM
PSI Chick's Avatar
PSI Chick
Default RE: Motor Mount Question?
there isn't a mount on the other side. there are two monuts located on the top and bottom on the left side.
Old Jun 6, 2005 | 05:01 PM
posthondaremoval's Avatar
posthondaremoval
The bottom mount is underneath, behind a plastic panel.
