STAGE 1 PSI Question
Old Jun 9, 2005 | 01:55 AM
DominicanSRT4's Avatar
DominicanSRT4
Default STAGE 1 PSI Question
Stock SRT4 is 11-13 pounds depending conditions.
How many pounds would a SRT4 be at with stage 1 ONLY?
Old Jun 9, 2005 | 02:03 AM
American__Muscle's Avatar
American__Muscle
Default RE: STAGE 1 PSI Question
Stage 1 is just fuel injectors and a PCM. I don't have it but im pretty sure the boost would be the same, but the fuel flow better. Right??? PSIChick, LilSparkPlug. The expert chicks
Old Jun 9, 2005 | 02:06 AM
American__Muscle
*max boost* is what i meant to say. It supposedly has a "better turbo response" and stuff but nothing that would actually increase the boost pressure.
Old Jun 9, 2005 | 03:25 AM
seanie719's Avatar
seanie719
With the stock wg and stage 1 your not going to see a big difference. (15 maybe)You need a higher rated spring wastegate to hold more boost. People using wastegates such as agp are setting theirs in the 17 18 psi range.
Old Jun 9, 2005 | 04:19 AM
bellosiciliano18's Avatar
bellosiciliano18
IMO-just wait a lil longer and go for the stage 2...
Old Jun 9, 2005 | 11:58 AM
71RoadRunner's Avatar
71RoadRunner
The Stage 1 is an upgraded PCM and injectors only for the '03's, the '04-'05 SRT-4's come from the factory with the larger injectors already in them, so Stage 1 for them is just the upgraded PCM. You will get 1-2 psi more boost over stock from Stage 1. Stage 1's mainly for increased throttle and boost response and it does great at both.
