Upper Heat Shield - Bolt Count?
I was preparing to replace my wastegate. I can see 5 bolts on the upper heat shield. Was wondering if there is a hidden "Bolt from Hell" that I do not see from upove? I assume the only difference in my Stage 2 wastegate from stock one besides the adjustable arm is maybe a heavier spring inside? I had read that the AGP WG opens at 14lbs. Anyone know the stock and Stage2 opening lb. levels?
ORIGINAL: Bob96
Correct on the s2 wga as well.
I am not sure on opening levels.
