Vacume Lines
Old Jun 19, 2005 | 07:21 PM
DominicanSRT4's Avatar
DominicanSRT4
Default Vacume Lines
PSIChick told me to check the diagram uner the hood and i noticed on the Siloniod number 3, i am missing the last to the buttom Vacume. I see the diagram and it seems to get somewhere to the Throttle body. So what i did was disconnected my BOV Hose which goes conncect to the Throttle body, and i pluged it there. I dont get anymore choking from the engine on 2nd gear, but i do get it in 3rd. Do anyone know where this vacume line goes connected?
Old Jun 20, 2005 | 12:12 AM
glhs837's Avatar
glhs837
Default RE: Vacume Lines
Okay, pin down which line you mean, by color, number and top, bottom, or middle.
Old Jun 20, 2005 | 04:39 AM
DominicanSRT4
The Vacuume line i am missing is on Blue #3, the Last to the bottom. What i did was i used the vacuume hose from the BOV to the throttle body and connected a T. Then i just put a custom line from that line to that selinoid. Dunno if its connected correctly. Can you guys check on your car and tell me where in the hell this goes connected too.
Old Jun 20, 2005 | 04:51 AM
black4's Avatar
black4
man dominican that problem still kicking your rear sounds to me like the person who owned it before you screwed up the vacume line routing hope you figure it out.
Old Jun 20, 2005 | 11:53 AM
glhs837's Avatar
glhs837
"last to the bottom". This is the line that's killing me. I don't want to assume which one. Is it the bottom one, or the middle one?
Becuase if it's the bottom one, and you tapped it into the middle one, then it's not getting the right stuff. When you say BOV, do you mean the stock one? That is the SVA on the digram, or surge valve. The computer uses the solenoid to control that line, which could be part of you problem. .
If you could describe what aftermarket parts your car has, if any, that would help too.
Old Jun 20, 2005 | 12:29 PM
DominicanSRT4
I have HKS BOV. On the Number 3 Silenoid, the last vacuum entrance to the buttom, it is missing, Can you guys look into your cars and check where that line goes too?
Old Jun 21, 2005 | 09:44 AM
glhs837's Avatar
glhs837
It goes to the throttle body, right where a line comes out and hits a big tee fitting.
