another bov question..
Old Feb 28, 2011 | 06:26 PM
rickyrod33's Avatar
rickyrod33
Default another bov question..
which hks bov sounds the best and will work well with a stock srt4?? i know i have asked a similar question im just kinda confused and dont want to end up buying the wrong bov.. thanks
Old Mar 1, 2011 | 12:31 PM
blacksunshine05's Avatar
blacksunshine05
HKS Super Sequential Blow Off Valve VERSION 3 and get a cold side pipe that will work with the blow off valve. You will also need to get a Blow Off Valve Block Plate for the stock turbo, because you will remove the stock valve.
Old Mar 2, 2011 | 12:16 PM
rickyrod33's Avatar
rickyrod33
O ok thanks..should I just get the kit? Will that include everything I need?
Old Mar 2, 2011 | 05:30 PM
blacksunshine05
Yes there are companies that make complete kits, one of them being modern performance
Old Mar 2, 2011 | 07:50 PM
rickyrod33's Avatar
rickyrod33
ok thanks alot for your help ill look for a kit from them... thanks for your help..
