fuel problem
Old Jul 6, 2005 | 02:58 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: fuel problem
Did you check the sensors? Or just attempt to reset the PCM??? If its not throwing a CEL light/code, then resetting the PCM won't do you any good.
Edit on that one, you said you checked the sensors.
Check the IAC valve, and the TPS wiring harness.....sometimes they act retarded, since they're shorter and tighter than they should be (i.e. MPSC's TPS Repair wire)
Old Jul 6, 2005 | 03:50 AM
PSI Chick's Avatar
PSI Chick
please describe exactly what it's doing and when it's doing it. just saying "jump" doesn't really give us a way to help you.
Old Jul 6, 2005 | 11:35 AM
t0973mf's Avatar
t0973mf
I had something like that so I changed the plugs and it smoothed out.
Old Jul 13, 2005 | 12:05 AM
manous04's Avatar
manous04
it fills like i am patting the gas really quick
Old Jul 15, 2005 | 12:29 AM
black4's Avatar
black4
does it feel like is a quick stab at part throttle then lets up?
Old Jul 15, 2005 | 02:03 AM
manous04's Avatar
manous04
ya but it not stop intel i mash the gas and when i let off of it starts back again
Old Jul 16, 2005 | 12:42 AM
black4's Avatar
black4
sounds like the wiring of the tps or the tps it self mine did the same thing.
Old Jul 16, 2005 | 01:41 AM
manous04's Avatar
manous04
thanks alot i'll see what i can do
