srt-4 help!
Old May 2, 2011 | 01:35 PM
pulleyk82's Avatar
pulleyk82
Unhappy srt-4 help!
I have a 2005 dodge neon srt-4. only mods are short ram air intake with oil catch can. it does have the stage 1 injectors but not the pcm. it does throw the p1188 code from time to time and then it goes away by it self. but the other day i was going down the road and noticed that i am not hearing the BOV when i shift anymore. the only time i can hear it now if i go WOT and get up to about 10psi and release and then i can hear it but the sound is shorter in lenght than before. anybody had this problem before or give me a direction to look into???
please help! thank you
Old May 8, 2011 | 12:12 AM
Moparmatt440's Avatar
Moparmatt440
1188 is just the TIP sensor performance, are you on pcm controlled boost? I know with some aftermarket bov they don't always blow off, or when they release the air is just barely opening but not makeing the full noise.
Old Jun 1, 2011 | 10:17 PM
wolf22m's Avatar
wolf22m
Tip sensor controls boost solenoid, so this could be your problem??
