Automatic transmission srt 4 question?
Old May 4, 2011 | 10:21 PM
stammybammy's Avatar
stammybammy
Default Automatic transmission srt 4 question?
What is the toughest automatic transmission that I could use with my 2005 srt 4 motor? The motor has lots of work done to it
Old May 6, 2011 | 03:58 AM
darthroush's Avatar
darthroush
Section Moderator
Probably one from a PT GT, which also has a turbo 2.4L engine.
Old May 8, 2011 | 12:05 AM
Moparmatt440's Avatar
Moparmatt440
The toughest auto trans made is from darrel *** racing, that will handle anything you put to it, they use it in their red sled which is in the 8s I believe. Its expensive but you wouldn't have to worry about it, you'd break a pt trans with a built motor.
Old May 11, 2011 | 10:45 PM
darthroush's Avatar
darthroush
Section Moderator
For $10 grand, it had better.
