srt 4 having some problems
Old Aug 19, 2011 | 05:03 PM
prez's Avatar
prez
Default srt 4 having some problems
i just bought this 05 srt4 a week ago with 40k on it and im having some problems with it... 3 days ago i pushed the gas all the way down and only got to 4psi then threw a code p0420 --catalyst efficiency low bank 1-- the car still wont go past 4 psi and now its starting to bog out pass 3k rpm. its also just started throwing 2 more codes p0171 --fuel system lean-- and p1188 --tip sensor performance-- i dont know much about these cars but from what i can tell the only mod on the car is an aftermarket down pipe with an electronic cut out thats not wired and a aftermarket boost gauge. need some helpppp
Old Oct 1, 2011 | 05:18 PM
turbo2point4's Avatar
turbo2point4
bad O2 sensor maybe? also make sure the tip sensor is hooked up 05s are sensitive about the tip sensor and the car is probably in a safe/limp mode so its only allowing 4psi, that would be my assumption since it has a lean fuel code
