its happened again!!!!WTF
Old Oct 3, 2011 | 08:31 PM
SRTUNIT2's Avatar
SRTUNIT2
Default its happened again!!!!WTF
ok here it is. on my way into work today, about a 10 minute drive, i am in 1st gear and i got to drive and the car starts to sputter again. now i say again cuz in april of this year the same issue happened. if seem to go away on its own. then 3 weeks later boom its starts again but this time it throw the check engine code. i take it to the dealership,where of course the problem is gone, so they say the spark plug well gasket is gone and oil is blowing out the spark plug. so i got it replaced and got new NGK spark plugs. issue gone till this morning same thing happened its sputtering again and now i am thinking is this the start of me having to go through this again. i am running ngk with a .38 gap on a mopar stage 2 04 srt-4 msd coil pack and wires. any help would be gr8 on trying to fix this repeating issue.
Old Oct 5, 2011 | 04:45 PM
turbo2point4's Avatar
turbo2point4
id say start with a stock coil pack they're good to 900hp, all i've heard is any other coil pack on srt's are junk, so id go back to stock
Old Oct 6, 2011 | 04:38 PM
turbo2point4
also check the plugs, and maybe replace your plug wires if they are old they should be replaced any way
Old Oct 7, 2011 | 10:18 AM
srt4tw89's Avatar
srt4tw89
it might be your throttle position sensor....same thing happened to me. mine got so severe that my car literally went into cruise control mode.
Old Oct 7, 2011 | 12:21 PM
turbo2point4
let the car idle and move the wires around to see if the idle changes at all you might need the tps rewire kit
Old Oct 18, 2011 | 12:06 AM
SRTUNIT2's Avatar
SRTUNIT2
i have notice it seems to happen a day or so after i fill the tank with gas. then today on the way home it wasnt sputtering at idle but when i hit the gas to about 10 psi it started back firing and sputtering. please help
