help
Old Jul 25, 2005 | 10:04 PM
srt4xnj's Avatar
srt4xnj
Default help
can anyone help my car for some reason revs to like 2 grand by it self once in a while. should i disconnect the batter to reset the icu?
Old Jul 25, 2005 | 10:51 PM
roachnigga's Avatar
roachnigga
Default RE: help
At start up? When?
Old Jul 25, 2005 | 11:35 PM
srt4xnj's Avatar
srt4xnj
Default RE: help
sometimes when im drivin and i stop at a light the i tap the gas and it stops
Old Jul 25, 2005 | 11:51 PM
roachnigga's Avatar
roachnigga
Default RE: help
3 things: Clean ya TPS Sensor; Replace ya TPS Sensor; Or its the TPS wire
Old Jul 25, 2005 | 11:52 PM
Olie70's Avatar
Olie70
Default RE: help
The dreaded TPS anyone????[sm=badbadbad.gif] If you get a chance, when acting up, jiggle TPS wire....if car sputters while jiggling almost stalling, you have a bad TPS connector and harness....You will notice it will get progressivley worse.....when in motion it will seem like car is on cruise control......Instead of hitting gas, just apply clutch, that will make it go away momentarily.....if you take it in to dealer to have them check it out, DO NOT SHUT CAR DOWN....it comes and goes and mostly goes when you need to show mechanic......
Old Jul 25, 2005 | 11:53 PM
Olie70's Avatar
Olie70
Default RE: help
Roach, you beat me to it.....
Old Jul 26, 2005 | 12:16 AM
srt4xnj's Avatar
srt4xnj
Default RE: help
whats the tps wire and where is it
Old Jul 26, 2005 | 12:49 AM
Olie70's Avatar
Olie70
Default RE: help
Located front drivers side under Airbox (or where it used to be). White 3 wired sensor near ECU. Search "TPS" in forum and you will get ALOT of hits on it...I even think there is a step by step for splicing and/or replacing. Usually, wire inside covering snaps due to wire wrapped aroung with no slack, causing snappage. ( is that a word???)
Old Jul 26, 2005 | 12:52 AM
srt4xnj's Avatar
srt4xnj
Default RE: help
ok thanx im just gona bring it to the dealer its under warrenty
Old Jul 26, 2005 | 01:05 AM
Olie70's Avatar
Olie70
Default RE: help
If you can get a good dealer who will know what you are talking about (It is a wide issue, but you never know) and It is gonna cost you, I think parts not covered....I am not sure, I spliced a wire into existing sensor for slack (Overseas and not a dealer around and no issues since....) Good Luck....
