Turbo problem
Old Nov 25, 2011 | 09:09 PM
Kenedy1315's Avatar
Kenedy1315
Default Turbo problem
i have 05 srt4. It was running great until like 3 days ago. It just stop spooling. i check all the vaccum lines and also the pipes from the intercooler and everything was fine. i didnt loose psi in the turbo. Can anyone tell me what could be wrong with the car? Ive havent had a tubo car before
Old Dec 11, 2011 | 10:20 AM
gen x muscle's Avatar
gen x muscle
did u check the turbo itself take it off and inspect the fins inside make sure it has no play. check your intercooler pipe coupling they may seem tight while its sitting there but under pressure they could be to loose and loosing pressure this is what a boost leak tester is for. those are just common things. do u hear any sound from the turbo or any really high pitched whistles.
