Boost Levels - Stage 0 - 1 - 2 - ?
Old Aug 9, 2005 | 07:40 AM
Bob96's Avatar
Bob96
Default Boost Levels - Stage 0 - 1 - 2 - ?
I was wondering what the PCM settings are for maximum boost on Stage0 - Stage1 - Stage2 w/o Toys?
Old Aug 9, 2005 | 10:12 AM
posthondaremoval's Avatar
posthondaremoval
Default RE: Boost Levels - Stage 0 - 1 - 2 - ?
If you are asking what is max boost, on each, they are around 12-15psi for stock and s1, and 17 for s2. With tweeking, you can push it further, but you risk things if you don't update/grade the fuelsystem...My s2 pushes around 17-18 in the heat with a higher spike. In winter it is between 16-17(sometimes lower) with a spike around 18.
Old Aug 10, 2005 | 06:24 AM
roachnigga's Avatar
roachnigga
YUP
