Stage 2
Old Aug 16, 2005 | 04:10 AM
roadwarrior03's Avatar
roadwarrior03
Default Stage 2
I'm new to the site. I have an 05 white srt4. My question is about the emmision problems I have heard about with stage 2. What code does it give. I did some research on this site and from what I understand if I keep my stage 0 pcm and injectors and reinstall them before testing I will be fine. If I could get some clarification on this subject It would help me alot. I live in Pennsylvania, if that needs to be known.
Old Aug 16, 2005 | 12:04 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 2
any ecu that has toys will cause a problem. i tried the whole installing s0 and it still failed, twice. there's a product coming to the market that will fix the issue, so it's taken care of. i was the prototype and it's the only way my car passed.
Old Aug 16, 2005 | 09:26 PM
roadwarrior03
Default RE: Stage 2
do u have any idea when the part will be out to fix that problem. I cant get the kit until next spring.
Old Aug 16, 2005 | 09:28 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 2
3-4 weeks or so any they should be out. one of the components is on backorder, but a new supplier was found.
Old Aug 16, 2005 | 10:31 PM
roadwarrior03
Default RE: Stage 2
thank you for the feedback
Old Aug 17, 2005 | 11:12 AM
black4's Avatar
black4
Default RE: Stage 2
cool keep us informed psi.
