TB Install Question???
Old Aug 27, 2005 | 05:10 AM
Bob96's Avatar
Bob96
Default TB Install Question???
I am installing my Lorenzo 60mm Throttle Body. I can not remove the white connector to the TPS Sensor? It does not have the Red Lock Clip like the others and as on the PCM connectors? Does anyone know how to remoce this White Connector to the TPS? I have removed the TPS with the connector attached but would rather install the TPS and then plug in the connector. Any tips in removing this White Plastic TPS Coccector/
Thanks!!!!
Old Aug 27, 2005 | 10:59 AM
posthondaremoval's Avatar
posthondaremoval
Default RE: TB Install Question???
I honestly can't remember, but I'll take a look in a bit and see if I can spark my memory.
Old Aug 28, 2005 | 06:13 AM
BlackDragon's Avatar
BlackDragon
You have to hold the lock tab and pull very firmly. Its usually on there pretty good.
Old Aug 28, 2005 | 09:54 AM
posthondaremoval
^^^^^^what he said. I just looked, and I remember now. It's a simple lock tab, just tough to push and a bitch to get off, especially with the bracket just plugged to the sheetmetal like it is.
