fuse showing up on odometer
Old Dec 1, 2012 | 01:47 PM
shaunamax's Avatar
shaunamax
Default fuse showing up on odometer
my car will start with a jump but shuts down when cables removed. the message "fuse" shows in the odometer when I try to start without jump, but will not start. all fuses show good when checked. any ideas?
Old Jan 15, 2013 | 05:51 PM
darthroush's Avatar
darthroush
Section Moderator
Could be a bad/corroded engine ground or a blown dome/trunk light as well. Both of those lights also serve as in-line fuses.
