Turbo Surge!!!
Old Sep 21, 2005 | 03:15 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: Turbo Surge!!!
ORIGINAL: srt4 driver
never experienced that.... my car is still stock
If you want to hear the horse laughing, just pull of the top of your airbox, you'll see what they are talking about - sounds cool, IMO.
Old Sep 21, 2005 | 06:01 PM
LilSparkPlug's Avatar
LilSparkPlug
ORIGINAL: PSI Chick
so if i'm reading this correctly, you're getting flutter when you let off the gas, correct? hearing flutter at that time is normal. if you are hearing flutter at full wot when the gas is down, then there's a problem.
Im getting flutter until full WOT, hard acceleration and it flutters really loud and fast. But Ive been told its okay.
Old Sep 21, 2005 | 08:37 PM
PSI Chick's Avatar
PSI Chick
you should only hear flutter when you let off the gas and are decelerating. when you're accelerating, the turbo should be spooling and should not flutter at all. now if you're accelerating and don't reach positive boost then you very well may hear some flutter, but once you hit boost it should not be present.
Old Sep 22, 2005 | 12:47 AM
wordslayer's Avatar
wordslayer
you can take and leave off the top of your air box???? It sounds better?
Old Sep 22, 2005 | 02:06 AM
LilSparkPlug
I still hear it under full boost.....[>:]
Old Sep 22, 2005 | 02:28 AM
posthondaremoval
ORIGINAL: wordslayer
You certainly can - it sounds pretty cool. Won't net you any improvement in performance, though - might possibly lose you a little due to heat entering what is a stock cold air system. It is one of those things that is fun to try for kicks. Your filter is a conical filter and doesn't need a lid to keep the dirt out, just to keep the heat out.
It is also a decent idea to pull the lid off the box if you haven't, to see why people always preach about catch cans and such, as there will be a good bit of oil in there from the crankcase vent.(Which, BTW is fine if you run the stock intake, since it is outside of the airstream and not internal)
Old Sep 23, 2005 | 02:54 AM
Pressurecooker's Avatar
Pressurecooker
Be advised that the lid does help to secure the filter in place. It may be cool to try once, but I'd keep it on for the day to day grind.
Old Sep 23, 2005 | 04:21 PM
Silverrt4's Avatar
Silverrt4
ORIGINAL: Olie70
Just a question, is it something you hear or do you see your PSI gauge fluttering really fast??
I hear the flutter noise and the boost gauge does the flutter too
Old Sep 23, 2005 | 04:23 PM
Silverrt4's Avatar
Silverrt4
ORIGINAL: PSI Chick
Yes it's at wot, too same sound
Old Sep 23, 2005 | 04:25 PM
Silverrt4's Avatar
Silverrt4
ORIGINAL: LilSparkPlug
ORIGINAL: PSI Chick
Same here, and I have positive boost. I have no clue what it could be, any suggestions.
