Having starting issues with my 05 Dodge srt4
So my srt4 was running just fine yesterday, started everytime, and today it wouldnt even crank over?
This is the first time it's done it. It has struggled to start before, but it would atleast crank and after putting it from first gear to nuteral or a second attempt it would start right up? My battery terminals look very worn out, but it all lights and even the stereo turn on, I tried jump starting it, and nothing happend, still wont crank. Im thinking it can be the little switch under the clutch pedal, but im not sure I would appreciate some help, feedback, opinions on what it could be, anyone thats had this issue before? Thanks |
Originally Posted by car2196035
(Post 3030633)
This is the first time it's done it. It has struggled to start before, but it would atleast crank and after putting it from first gear to nuteral or a second attempt it would start right up? My battery terminals look very worn out, but it all lights and even the stereo turn on, I tried jump starting it, and nothing happend, still wont crank. Im thinking it can be the little switch under the clutch pedal, but im not sure I would appreciate some help, feedback, opinions on what it could be, anyone thats had this issue before? Thanks Jumper out the safety switch, as in, make it constantly "pressed" by bypassing the switch with another wire or whatever. If your car won't crank after that and you aren't hearing the starter click (i assume) I would try replacing the starter because frankly I'm not quite sure what else could ever cause a no-crank situation with power except a safety disconnect switch... |
