srt4 upgrades?
Old Oct 17, 2005 | 10:51 PM
pc11286's Avatar
pc11286
Default srt4 upgrades?
i have a 05 srt-4. i have intake already and im looking for other mods to do? i thought about a bigger turbo but im not sure. any suggestions?
Old Oct 18, 2005 | 03:00 AM
Gump's Avatar
Gump
Default RE: srt4 upgrades?
well since you dont have any supporting mods for a turbo id say no... what intake do you have?
if i were you and i was planing on upgrading my turbo then id get every supporting mod on that i could before hand. ie exhaust, proper intake, intercooler, wires, plugs, motor mounts, hard pipes, bov, wider wheels and tires, injectors, wastegate... the list is quite long if you want to do it correctly and get the benifit out of it. or just go and get S3 but id still get an exhaust and motor mounts and wider wheels and tires.
what turbo do you want to get? would probally be the best question for me to ask you so i can see where you want to go mods wise.
Old Oct 18, 2005 | 12:50 PM
posthondaremoval's Avatar
posthondaremoval
^^^What he said - what is your goal. Where do you want to be when you are done? How much do you want to spend?
Old Mar 17, 2006 | 06:39 AM
moparman04's Avatar
moparman04
STAGE ONE FIRST ... CHEAP AND YOU CAN FEEL IT
Old May 20, 2006 | 02:12 AM
ironicsrt's Avatar
ironicsrt
your stock turbo can support up to 20 psi your fuel system can only support 16 psi i suggest you work on your fuel system. the only thing i put on is a boost controler, k&n filter, and waste gate. it should pu tyou in the mid to low 13's. if you work on fuel system you can boost more than my 16 psi.
Old Jun 1, 2006 | 09:44 PM
Nicky B's Avatar
Nicky B
I say get all the bolt-on's and wires that were listed in the previous posts and then get a stage 2 turbo so your pushing over 300HP without even the high-octane mode on. That is what I have been planning MAYBE. Over 300HP and you are looking at high 12's with good tires.
