Many Many Questions
Old Nov 1, 2005 | 07:45 PM
hothunnyracer's Avatar
hothunnyracer
Default Many Many Questions
So this is going to sound dumb, but I have a question .. . . . do you have to have a stage 1, then buy the stage 2 or can you just buy the stage 2 first
Old Nov 1, 2005 | 07:48 PM
wordslayer's Avatar
wordslayer
Default RE: Many Many Questions
Ahem!
question ****I**** can answer. Stand back and watch my smoke.
No. You can start out with either stage one, two or three. There is no order in which to buy the stages. If you buy stage two, get the toys!
References:
Posthondaremoval 10/4/05, in thread explaining why toys are important
Old Nov 1, 2005 | 08:01 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Each stage is different, Stage 1 is not compatable with Stage 2, etc. You might want to "casually" ask your dealer their warranty policy on Stage upgrades. Unless you are looking for it, a Stage 1 is not going to be noticed by someone doing minor maintenance on your car unless they run the codes and see "0633". Stage 2 and Stage 3 are pretty obvious......
Dusty
Old Nov 1, 2005 | 08:34 PM
PSI Chick's Avatar
PSI Chick
warranties are over rated
Old Nov 1, 2005 | 08:38 PM
srt4babe's Avatar
srt4babe
So what is it about all 3 stages, whats the best. Can you start with a stage one then add stage 2 and on and on
Old Nov 1, 2005 | 08:40 PM
PSI Chick's Avatar
PSI Chick
www.mopar.com
also try here
there are stickies for a reason
Old Nov 1, 2005 | 09:00 PM
bigham's Avatar
bigham
wow is that the almighty hamster again
Old Nov 1, 2005 | 09:40 PM
highrevr/tflea's Avatar
highrevr/tflea
hey hamsties are scarce around here for scary reasons....run!!!!!!!!!!
Old Nov 1, 2005 | 10:02 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
ORIGINAL: PSI Chick
...not if you bought all the ones they offered, like I did.
I sleep well at night, if not a bit lighter in the wallet......and I get treated VERY WELL at the dealership, thank you!
Dusty
Old Nov 2, 2005 | 01:15 AM
LilSparkPlug's Avatar
LilSparkPlug
ORIGINAL: dustyloins
ORIGINAL: PSI Chick
Dusty
Same here!! I got the MaxiCare 0 deductible warranty until 70k miles. Full coverage!!
Wordslayer...PSIChick found your hampstie!!
And yes there are stickies for a reason.....to read!!!
