PERFORMANCE?
Old Nov 4, 2005 | 02:44 PM
flameredsrt's Avatar
flameredsrt
Default RE: PERFORMANCE?
No..stage 2 doesnt come with a tt.If you do stage 2 highly advise to get the turbo toys.
posthondaremoval's Avatar
posthondaremoval
ORIGINAL: chasem167
ORIGINAL: posthondaremoval
My opinion:
Get a good exhaust. You will want it no matter where you take the car, and I personally don't trust a simple boost controler. Get the turbo toys when you go s2 - it has a multi staged boost controller as well as other plusses built in. The first of the year is coming up soon, so skip the wastegate, s2 comes with a good one, and you won't have to mess with vac. lines, which never seal the same way once you pull 'em once.
You could do a Maxxfab downpipe with a side exit pipe for that money, or a 3" dp with a borla exhaust. Both are good choices.
Does the stage 2 come with a turbo timer? Im installing one this weekend in the same spot as the toys just to keep the turbo in good condition. It will get its usage even before i put a stage 2 in the car with toys so its not a bad purchase. again just wondering if that was a addition to the stage 2.
S2 has no turbo timer, and you can keep it when you go that route. Obviously you'll have to re-locate it to some place like the little tray on the dash or under the steering wheel or something, but it will help s2 in the same way it helped stock.
Old Nov 5, 2005 | 05:04 PM
Gump's Avatar
Gump
maxfab used to sell a single tip muffler exhaust that ive heard on a car and its super quiet. looks like a fart can but it doesnt sound like it. the guy that had it told me that they dont sell it but it sounded good enough to check aroudn.
