want to run a turbo need help
Old Nov 7, 2005 | 08:24 PM
spinxracer's Avatar
spinxracer
Default want to run a turbo need help
i have a friend that has a factory turbo for sale and i also have another friend that said he no no someone that sells a adapter plate. this plate alows for the 2.4 exhaust manifold adapt to the 2.0 block. i no some of the things is need but i need some more advice.
how is the turbo to manifold set up on the srt4 or can someone send me a link or a pic of how its set up
i know i need
afc
fuel pump
fuel injectors
fuel pressure regulator
intercooler
blowoff valve pressure pipe and blow off valve
piping for the intercooling system
down pipe exhaust
extra stuff im putting on
ignition system
spark plugs and wires
coil pack
crank
bearings
studs
rods
8:8:1 compression pistons
cam
intake
throttle body
Old Nov 9, 2005 | 06:45 PM
got boost?'s Avatar
got boost?
Default RE: want to run a turbo need help
I'm assuming this is for a non-srt neon. Instead of going through that hassle why not invest in a direct bolt on turbo KIT. For about $3500 you'll get pretty much everything you need to run a turbo. Heres a couple of links for kits....
http://www.chillfactory.us/autoturbokit.html
http://www.modernperformance.com/dcx/pl2000_index.shtml
Good luck my friend!
