sputtering???
Old Nov 9, 2005 | 07:01 PM
aalva79's Avatar
aalva79
Default sputtering???
Yea ummm, i dont know if anybody has had this problem but my 04 srt has been sputtering every now and then at low rpm's
and when idling. whenever i floored it it would stop for some time, but the it would come back, then i added a fuel injector cleaner and seemed to have stopped the sputtering, and iam hping it wont come back. Wondering if anybody has had this problem or any feedback.
All stock with a BOV runnig 94 octane
Any feedback is greatly appreciated
Thank You
Old Nov 9, 2005 | 07:08 PM
got boost?'s Avatar
got boost?
Default RE: sputtering???
Could be the plugs or wires...
Old Nov 9, 2005 | 07:39 PM
posthondaremoval's Avatar
posthondaremoval
If you are on original plugs and wires - definitely replace them. Get some MSD plugs or something of that level, and plugs should be replaced at least every 10,000 miles with this car.
Do you have any rpm fluctuation with the sputtering?
Old Nov 9, 2005 | 07:44 PM
aalva79's Avatar
aalva79
thanks guys
Car rpm fluctuate at idle almost to the point of stalling out, and i still have the original spark plugs and wires but i think i will change them thaks for the advice.
anymore feedback is appreciated
thank you
Old Nov 9, 2005 | 07:50 PM
posthondaremoval
ORIGINAL: aalva79
thanks guys
thank you
plugs and wires should do the trick - i was thinking tps if you were having an INCREASE in rpm, but if it is stalling, it probably isn't getting spark. get in the car, close the door, put the key in the ignition, and cycle it from position 1 to position 2 - 3 times., but do not crank over past the resistance point where your car will start. After the 3 cycles, look at your odometer display. See if it throws any codes. If it doesnt, and just comes up with dashes, then says "done" you should be cool with the plugs and wires. You will see if it is throwing/has thrown codes for misfires, injectors...
P0159<----it will look like(not those numbers, just that format) if there is a code.
Old Nov 9, 2005 | 08:00 PM
aalva79's Avatar
aalva79
thanks posthondaremoval i will try those tips and iam certainly getting new wires
thanks for the help
Old Nov 10, 2005 | 03:41 AM
PSI Chick's Avatar
PSI Chick
tps issue?
