Problem with the plugs?
Old Nov 16, 2005 | 01:56 PM
got boost?'s Avatar
got boost?
Default Problem with the plugs?
Hey my '05 SRT has learned a new trick today. I was at a stop light when my car shuttered and damn near stalled out. Is it time to switch out the plugs and wires or is this a fluke?
Old Nov 16, 2005 | 03:12 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: Problem with the plugs?
ORIGINAL: got boost?
stalling is never really just a fluke in a car this new. sounds like a possibility. How many miles have you put on?
Old Nov 16, 2005 | 03:48 PM
Gump's Avatar
Gump
a lot of people will say to change them out to ngk 4603's any way so its up to you on how soon you do it. its less than 10 bucks so it cant hurt.
Old Nov 16, 2005 | 04:16 PM
posthondaremoval
ORIGINAL: Gump
Good point - those v-powers are good stock heat range plugs. I ran them before I switched to densos. On the wires - get some msd's or go to sparkplugs.com and get their 10 mm shielded. The wires alone smoothed out my idle significantly.
Old Nov 17, 2005 | 01:42 PM
PSI Chick's Avatar
PSI Chick
check the tps wires also
Old Nov 18, 2005 | 12:18 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yup, new wires are just plain good insurance, the stock ones suck. I have MSDs and haven't had any problems in almost two years.
Dusty
Old Nov 19, 2005 | 04:41 PM
got boost?'s Avatar
got boost?
I was eventually planning on doing it anyways sooo... but to answer your question, Adam, it has 2009 miles on it.
