Still Same Problem :-(
Old Nov 23, 2005 | 10:18 AM
aalva79's Avatar
aalva79
Default Still Same Problem :-(
Changed wires to MSD and spark plugs to NGK Irridiums ans still i get sputtering, its not all the time but every now and then i get a sputtering from the car when i drive in low RPM's and then some serious popping from the exhaust. PSI Chick said something about TPS but dont know where to start with that.
PLEASE HELP!!!!
Old Nov 23, 2005 | 11:57 AM
PSI Chick's Avatar
PSI Chick
Default RE: Still Same Problem :-(
read this
Old Nov 24, 2005 | 05:24 AM
posthondaremoval's Avatar
posthondaremoval
Sounds like a trip to the dealer is in order. In this case, it is generally a quick replacement(depending on whether or not you have a good shop) and covered under warranty.
