Clutch question
Old Dec 8, 2005 | 06:34 PM
Signal Flow's Avatar
Signal Flow
Default Clutch question
I recently installed an FX300 clutch on my vehicle. I feel a slight vibration on first and reverse. I was just wondering if that is normal for the break in period, or if there is something wrong.
By the way the mechanics that installed the clutch said it was normal for the break in period.
Your suggestion would be greatly appreciated.
Thank you
Old Dec 8, 2005 | 07:47 PM
PSI Chick's Avatar
PSI Chick
Default RE: Clutch question
it's called chatter. it will never go away, only lessen after the clutch is broken in.
Old Dec 8, 2005 | 08:28 PM
Signal Flow
it will never go away?!
