can any one help.
Old Apr 26, 2004 | 12:15 AM
1badsrt4neon's Avatar
1badsrt4neon
Default can any one help.
i have a 04. i put on cold air and the greddy blow off, and a wastegate actuator. Me and my friend tuned it and it would go to 14 psi and then it would drop off to 11 psi. anyone know what i can do
Old Apr 26, 2004 | 02:11 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: can any one help.
What brand of cold air did you put on???? On an SRT-4, most are a waste of money due to the high temps in the engine bay....there's NO cold air there and if you put it lower, you run the risk of sucking up some water/snow, or both.....sorry, didn't mean to burst your bubble....
Do you have any stage upgrades?
Old Apr 26, 2004 | 06:11 AM
71RoadRunner's Avatar
71RoadRunner
I have heard of others having the same problems after installing an after market wastegate actuator. Check out SRT Forums for more info on your problem.
