NEED SOME TECH ADVICE
Old Jan 7, 2006 | 04:33 PM
PCAR310's Avatar
PCAR310
Default NEED SOME TECH ADVICE
got a bit of tech question. i have been looking at the agp wastegate actuator and the greddy boost controller and was wondering which would be better performance wise or if both at the same time would be better.i took my stock srt-4 to the track yesterday for the first time and ran 14.2 against another srt-4 with the actuator and boost controller he ran 15.2 , that kind of confused me because i read that he should be in the 13's . any help would be appreciated
[IMG]local://upfiles/26922/67860A140A35475FAAAD64886536B8EA.jpg[/IMG]
Old Jan 7, 2006 | 08:17 PM
Gump's Avatar
Gump
Default RE: NEED SOME TECH ADVICE
What you run at the track has way more to do with driver skill than mods. stock i ran 14.1 at 98mph after all my mods i still put down 13.9-14.1 at 104. ive seen a 06 z06's run 14.9...
Id just get the wastegate since a lot of people cause more harm than good with a boost controler.
Old Jan 8, 2006 | 04:30 PM
PSI Chick's Avatar
PSI Chick
both is the best set up, but if you have to choose one over the other the wga is a better choice. just because a car can do a 13s run doesn't mean that the driver can get it to do it....don't let one car make your mind up about mods.
Old Jan 8, 2006 | 06:10 PM
coyoteyz13's Avatar
coyoteyz13
I have the AGP and like it. If you do get the WGA, be careful not to turn the boost up too high if your car is stock otherwise.
Old Jan 9, 2006 | 02:00 AM
PCAR310's Avatar
PCAR310
What would be the highest boost setting u would reccomend while everything is stock?
[IMG]local://upfiles/26922/34808ABAE58740C0B8074FA4DD19CDE2.jpg[/IMG]
Old Jan 9, 2006 | 02:12 AM
LilSparkPlug's Avatar
LilSparkPlug
No more than 16 spike.
Old Jan 10, 2006 | 02:05 PM
rx8driver's Avatar
rx8driver
ORIGINAL: PCAR310
I love this set up. I am running 18 psi falling to 15 at redline, but you need stage 1 to raise the boost over 16. In my opinion the wastegate and boost controller are useless without stage 1 but adding them to stage 1 is very effective.
