few quick questions
Old Jan 16, 2006 | 08:21 PM
1fast04neon's Avatar
1fast04neon
Default few quick questions
first does anybody have directions on how to wire in a hard core alarm and remote starter. this thing is a major ordeal, the windows role up and all kinds of wacky stuff. so just wondering if anybody had a full wiring diagram.
second is for S2 (should be here friday but the motors gettin rebuilt so i cant even put in on, the sux) but where is the tip sensor located?? also how do i set pre load on the wastegate and what do i set it to? also is there alot of tuning involved or is it just plug and play????
thanks a lot
mike
Old Jan 16, 2006 | 11:08 PM
American__Muscle's Avatar
American__Muscle
Default RE: few quick questions
plug and play...that's what people like about the mopar kits.
Old Jan 17, 2006 | 03:19 PM
1fast04neon
i was also wondering if any body knows where i can get just the bolts and gaskets for the mopar blow off valve. just had a new turbo put on and need new gasket and bolts so if any one knows its apprciated greatly. Havin tons of fun with the car but at a great expence..... lol
Old Jan 17, 2006 | 07:03 PM
PSI Chick's Avatar
PSI Chick
1. no idea where to get those schematics, sorry.
2. tip sensor is located on the fender on the driver's side.
3. preload to 4mm. to do this, mark the wga when it's off the car with a black marker on the arm. then install it. to measure tape together 4 dimes and put that in the space between the black mark that you made and where the arm is resting after install. adjust it if needed until it's 4mm. you might have to readjust later, not every car works best with a 4mm preload, but it's a good place to start.
Old Jan 17, 2006 | 10:37 PM
1fast04neon
ok thanks do u know about the bov gaskets no body can get them??
Old Jan 18, 2006 | 04:41 AM
PSI Chick's Avatar
PSI Chick
why do you need bolts? the gasket can be made from regular paper gasket material or you can cut a metal piece. if anything, try giving jeff@mpsc a call and see what he can do for you, he's great at getting his hands on hard to find stuff (i've tested that a few times....never been disapointed yet!)
