STAGE 1 ??????
Old Jan 18, 2006 | 12:55 AM
ACDCSRT4's Avatar
ACDCSRT4
Default STAGE 1 ??????
I WAS JUST WONDERING ON HOW GOOD THE STAGE ONE I WANTED TO KNOW IF U COULD REALLY FEEL A BIG DIFFERENCE COMPARED TO RUNNING STOCK. ALSO ON SOUND DIFFERENCE, AND HOW DIFFICULT IT IS TO INSTALL CUZ I NOTICED IT COMES WITH BIGGER INGECTORS RIGHT? I HAVE AN 04 SRT SO I HOW MUCH MORE HP FROM STOCK DOES IT ADD
Old Jan 18, 2006 | 01:10 AM
rx8driver's Avatar
rx8driver
Default RE: STAGE 1 ??????
https://dodgeforum.com/m_265244/tm.htm
Read this sticky, it provides great info about stage upgrades. It is very easy to install and you don't have to worry about injectors because you have an 04. As far as sound I noticed more pops and a deeper tone on downshifts. It is definitly worth it.
Old Jan 18, 2006 | 01:52 AM
ACDCSRT4's Avatar
ACDCSRT4
RX8 WHAT ELSE DO U THINK I SHOULD UPGRADE SO IT COULD BE GOOD WITH THE STAGE ONE CUZ RIGHT NOW ALL I HAVE IS A K&N COLD AIR AND THE MOPAR BOV
Old Jan 18, 2006 | 01:08 PM
71RoadRunner's Avatar
71RoadRunner
There are too many things you can do to list. Are you just looking for more power or better use of the power or handling, etc.?
Old Jan 18, 2006 | 04:53 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Consider the Mopar/Borla exhaust. It'll make the pops and gurgles from the Stage 1 even more pronounced.....
Dusty
Old Jan 18, 2006 | 06:29 PM
RIPSIGUY's Avatar
RIPSIGUY
My favorite feature of Stage 1 is the snaps and pops out the exhaust. Stage 1 is a logical step to start your upgrades. If you go with stage 2, the stage 1
is really easy to sell.
Old Jan 18, 2006 | 09:04 PM
posthondaremoval's Avatar
posthondaremoval
There are a lot of ways to go - one thing to do that is a good idea and pretty cheap is to get a acr rear sway and a pt front sway (they are 110 or so for both). There is a mopar tension strut to help rear end stability under brake load for 45$. All 3 will go with whatever you do in the future, and do a lot to help handling and getting the rear end around in turns.
