Boost gauge question
Old Jan 26, 2006 | 04:52 PM
Qdiddy's Avatar
Qdiddy
Default Boost gauge question
can someone tell me where the boost guage needle is supposed to be at when idle in neutral with a stock SRT-4, reason is mine keeps changing and i was wondering if thats normal or do i have a possible issue? Thanks
Old Jan 26, 2006 | 05:22 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: Boost gauge question
With the AC off you should be around 20 vaccuum.
Old Jan 26, 2006 | 05:25 PM
BigE's Avatar
BigE
mine sits at 19-20 at idle. Doesn't move at all while idling, if I look real colse maybe I can tell it is twitching just a bit between 19½ and 20. So if your leedle is moving more than that, or if your reading lower than 19, start checking for vacuum leaks.
Old Jan 26, 2006 | 06:09 PM
Qdiddy's Avatar
Qdiddy
ok cause i'm at about 15-17 right now so i guess i got a vacum leak thanks alot guys
Old Jan 26, 2006 | 06:46 PM
posthondaremoval
ORIGINAL: Qdiddy
Or a bad guage.
Old Jan 27, 2006 | 06:21 AM
black4's Avatar
black4
is that with a/c on if so that is normal.
Old Jan 29, 2006 | 04:37 AM
Qdiddy's Avatar
Qdiddy
no a/c not on just in neutral stopped no air on at all, but my boost is normal
