Ok LSP, i know you've heard this a bazillion times
How do you change the LED in the gauge pod, the color scheme for my car is Silver/Black with blue LED's and Neons. So naturally I need to change the dash, I saw you had it.... its super tight, just point teh N00B to the old thread (or repost info) and BANG! Lo Apprecio Mucho.
take apart your dash and pull out the cluster. remove the old bulbs and put in the new ones. put everything back together. it's really that simple. just be sure that the led's are working before you reassemble the dash as led's are polarized, so they need to be installed the correct way.
if you need the bulbs, you can get them from n2mb racing. you can find them on a few other forums and their websie should be up soon. those are the bulbs that i'm using now and they're great. i had the ones from autolumination and they were horrible.
1. Pull off the A-pillars, pull downward on an angle with slight force
2. Grab your shorty phillips head screwdriver, and a regular one. Theres two screws in the central vent on the top of the dash on either side, youll need the shorty for those. Then theres two (one on either side) of the dash where the doors close onto.
3. Push upward with slight force to get the clips to un-do themselves
4. Unplug the boost gauge. If its the boost gauge you want to change the bulb in, theres two screws underneath the boost gauge, sort of behind it, that hold it into its little "pod"
5. Wanna do the dash too? Four screws on the instrument cluster. Unscrew those, and pull it straight out.
6. The bulbs your changing are the LARGER ones. Use some needlenose pliers and a rag to get them out if they're being stubborn.
7. Swap the bulbs put it back together and your good!
