Just got out of the Dyno
Old Feb 4, 2006 | 09:10 PM
DominicanSRT4's Avatar
DominicanSRT4
Default Just got out of the Dyno
Well, i just got out of the dyno after installing the 0016 Cams, Cam Gears, FMIC, Stage1, 20 Psi Boost and i was surprised. I pulled a 327 HP and 340 ft torque while spinning tires 4th gear pull. I dynoed before without the cams at 262hp and 312 torque. I didnt get a/f measured cause i was short on cash and they were asking for tooo much money for whole package. So i only got HP run. I had a 40 hp increase at redline. Keep a look out, i have to take this sheet to my friends scanner to upload it.
Old Feb 5, 2006 | 03:08 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Just got out of the Dyno
Looking forward to it..............
Dusty
Old Feb 5, 2006 | 03:11 AM
Pressurecooker's Avatar
Pressurecooker
Friggin awesome dude! High fives all around! You're the shizznit. Now lets see some qtr times! Lets put it in ink.......
I got a stage 2 computer.......... You're giving me high hopes of beating my buddy with his supercharged GP who runs 13.4's ( modded)......
Old Feb 5, 2006 | 03:33 AM
wordslayer's Avatar
wordslayer
Matt...you have stage two on your car? I thought you were stock? I know your best time is like 13.89, so I am guessing you haven't run a 1/4 mile time yet with the stage two on your car, right?
Old Feb 5, 2006 | 05:23 AM
black4's Avatar
black4
hows the idle on the 16s?
Old Feb 5, 2006 | 01:46 PM
DominicanSRT4
At first the idle sounded crazy like a super race car. I actually like it. But after i tuned the cam gears, the idle is completely stock. I believe there is more power in these cams and cam gears. Just have to spend more time tuning. NIMO IF YOU OUT THERE!!!! FIND ME MORE POWER!!!!!!
Old Feb 6, 2006 | 12:02 AM
American__Muscle's Avatar
American__Muscle
ORIGINAL: wordslayer
Sounds like he just got the s2 ecu recently...
Old Feb 6, 2006 | 01:40 PM
05dodgesrt4's Avatar
05dodgesrt4
dominican what are your exact mods?
Old Feb 6, 2006 | 05:18 PM
DominicanSRT4
My exact Mods are : 2003 SRT4: Stage 1 Kit, LSD TRANNY, Stock turbo with AGP WGA at 20 PSI hold 18 at 6K RPM, Cold Pipe with HKS BOV, MSD Wire / coil, NGK Iradium Plugs, LARGE FMIC, Center Force Dual Friction Clutch, Crane Cams 0016, Cam Gears (tuned), Re routed Vacumm system (No Cylinoids Used), Custom made Return Line System @ 50psi. I think i got everything. Oh yea and a Ebay Pulley, Custom made 3inch Exhause from the Manifold to the Back with a apexi 3inch Inlet BIG DOG WOOOF WOOOOOOF Muffler (came out of a toyota supra.
Old Feb 6, 2006 | 07:28 PM
05dodgesrt4
so basically stock fuel system? and everything is fine with that? what im getting at is in an earlier post ripsiguy said that the amount of boost similar to yours os too much for the stock fuel system and woudl probably end up blowing a piston i was wondering how long you have had this set up and how it is doing? i have similar mods minus the intercooler, custom return line and rerouted vacuum everything else is exact sounds like a good setup if you have no probs ill prob get the intercooler and use your return line when you post the instructions
