o4 srt computer help stage one?
Old Feb 6, 2006 | 03:57 PM
dazzellers_95's Avatar
dazzellers_95
Default o4 srt computer help stage one?
hi, i have a 04, but i was looking at the ecu, it says " mopar performance stage 1 turbo" on the sticker that is over another sticker. and another one says " attention this module is only for use in vehicle with vin ending in...578842. the computer number is 1-p4510055ae, is this an upgraded ecu from stock or not? i amthinking it is but i dont know for sure, where can i find one like it on the intre-web? thanks in advance.
Old Feb 6, 2006 | 05:12 PM
posthondaremoval's Avatar
posthondaremoval
Default RE: o4 srt computer help stage one?
ORIGINAL: dazzellers_95
If you bought the car used - it is completely possible that the ecu is a stage 1 and has been reprogrmmed to run your vin and skim codes. I am assuming htat you checked your vin and that it is different than the one listed on the ecu?
Old Feb 6, 2006 | 05:45 PM
dazzellers_95
no, vin is the same, we got this srt from a "total" i own a junk yard, just tryin to find out about this damn ecu for a price to enter in inventory. is it an upgraded ecu then?
Old Feb 6, 2006 | 05:50 PM
FSTSRT4's Avatar
FSTSRT4
it most likely is a stage 1 upgraded ecu. However, whoever buys this ecu will have to have there vin programmed into it to make it work in there car. Also, this ecu will NOT work in an 05 srt-4. It will, but a check engine light will be on all the time.
Old Feb 6, 2006 | 06:11 PM
LilSparkPlug's Avatar
LilSparkPlug
Yup thats a Stage 1 PCM, Put it in the computer or sell it on here for like 200-250 bucks if its perfectly fine. Thats an easy piece to make money off of. As stated before its for an 04 only.
Old Feb 7, 2006 | 11:56 AM
BigE's Avatar
BigE
Someone will want it...
Old Sep 30, 2010 | 12:57 AM
Fabion's Avatar
Fabion
Whats ??? I done understand . chicago real estate*
