apexi turbo timer
Old May 10, 2004 | 03:36 AM
SRTUNIT's Avatar
SRTUNIT
Default apexi turbo timer
i went to get my apexi turbo timer installed and the guy that did it sd o2 sensor feature isnt working cuz had problem hooking it up, i guess he kept gettin a check engine light so disconnected battery and the system re-set, but now i dont have that feature. was wondering if anyone else had problem and if so how do u fix. And yes we contacted apexi and they said everything should work ok.
Old May 10, 2004 | 03:43 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: apexi turbo timer
The O2 sensors on the '03 and up cars don't seem to be compatible with anything except the PCM. No one that I know of has had any success with adding anything that has to connect to the O2 sensor, including gauges(even the one's from Mopar Performance). They all seem to require a new/different O2 sensor.
Old May 10, 2004 | 03:10 PM
roachnigga's Avatar
roachnigga
SRT,
WHAT RR IS SAYING I AGREE. IVE BEEN SEARCHING AND NO LUCK... I TOO HAVE AN APEX TT... MY O2 WIRE IS NOT CONNECTED....[&:]
Old May 11, 2004 | 04:24 AM
Gump's Avatar
Gump
Good to know casue i was goin to get that type of turbo timer and the O2 stuff wasnt a big selling point but thats good to know for installation purposes.
Old May 13, 2004 | 01:17 AM
SRTUNIT's Avatar
SRTUNIT
yes the o2 sensor isnt hooked up but at least i dont have to buy the air/fuel gague or volt meter the TT does do that.
