trouble codes!!
Old Mar 14, 2006 | 07:46 PM
PSI Chick's Avatar
PSI Chick
Default RE: trouble codes!!
haha it means that you're not doing it right. if you have no codes (which you do, anytime a check engine light is thrown there are codes) then it will display "done". you have to hold in the key lock when cycling it so that it goes to the "on" position.
Old Mar 15, 2006 | 05:23 PM
Plan B's Avatar
Plan B
Ok, I'll give it a try. Thanks PSI!
