p2074
Old Mar 8, 2006 | 02:28 PM
srt4indy's Avatar
srt4indy
Default p2074
I recently bought a 05 srt I have afew upgrades aem cai,agp wg.I am still stage 0, and everyonce in a while i will throw a p2074.anyone else throw this code and why would it throw this code?
Old Mar 8, 2006 | 03:23 PM
PSI Chick's Avatar
PSI Chick
Default RE: p2074
P2074-manifold Pressure/throttle Position Correlation
CORRELATION - HIGH
FLOW/VACUUM LEAK
When Monitored: Engine Running, during all drive modes.
Set Condition: If vacuum drops below 1.5 Hg with engine RPM greater than 2000 RPM
at closed throttle.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
VACUUM LEAK
HIGH RESISTANCE IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN MAP (K7) 5 VOLT SUPPLY CIRCUIT
MAP SENSOR
HIGH RESISTANCE IN (K1) MAP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K1) MAP SIGNAL CIRCUIT
HIGH RESISTANCE IN (K4) MAP GROUND CIRCUIT
PCM
TP SENSOR OPERATION
HIGH RESISTANCE IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
RESISTANCE TO GROUND IN (K6) TP SENSOR 5 VOLT SUPPLY CIRCUIT
TP SENSOR
HIGH RESISTANCE IN (K22) TP SIGNAL CIRCUIT
RESISTANCE TO GROUND IN (K22) TP SENSOR SIGNAL CIRCUIT
HIGH RESISTANCE IN TP (K4) SENSOR GROUND CIRCUIT
seems like this is a problem in the 05's that don't have the reflash done. it's usually found otherwise in conjunction with overboost codes. is this the only code that you are throwing?
Old Mar 9, 2006 | 12:11 PM
srt4indy's Avatar
srt4indy
Default RE: p2074
yes this is the only code. at first it was overboost code but i did some vac line mods and now no overboost codes but everyonce in a while i throw p2074.it only happens once in three months if even that all i do now is reset the computer and it fine for a while but i want to make sure i am not messing up my motor.also if its not messing up the motor is there a way to tune this out ?
Old Mar 9, 2006 | 03:05 PM
PSI Chick's Avatar
PSI Chick
Default RE: p2074
did you have the reflash done? other than that the only way to get rid of it seems to be s1......
Old Mar 10, 2006 | 02:05 PM
srt4indy's Avatar
srt4indy
Default RE: p2074
no I didnt have it reflashed.I figured the s1 would be the solution.thank you for the help.
