630cc injectors
Old Mar 16, 2006 | 04:28 PM
05dodgesrt4's Avatar
05dodgesrt4
Default 630cc injectors
will 630cc injectors be a good match for stg1 ecu and agp wga at 20psi?
Old Mar 16, 2006 | 06:31 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: 630cc injectors
Nope. Buy an SAFC or an SAFC-II. You need something to manage them or the car won't run properly. You can't just stick those in there without a managing system. And stock is somewhere around 587ccs, so why bother with 630ccs when its only slightly more. For the price of injectors you pay to play, so hop up a notch to a 750cc injector.
Old Mar 16, 2006 | 06:38 PM
BigE's Avatar
BigE
Can you get the injectors and also get a 'Map Clamp' and trick the ECU to adding more fuel? Cuz' I'm not sure, I'm still learning about this to.
Old Mar 16, 2006 | 06:47 PM
05dodgesrt4
i have a mbc how do you install it its the kind that stays under the hood
Old Mar 16, 2006 | 06:56 PM
LilSparkPlug
No, the mapclamp is meant for cars with more fuel that want to lean out a bit more. All the Mapclamp does it take away fuel, it doesn't give you more.
It also tricks the map's voltage and confuzzles the PCM.
Old Mar 16, 2006 | 08:10 PM
vaughn's Avatar
vaughn
heres a cool kit if you got the cash http://www.modernperformance.com/dcx...rtfueler.shtml
Old Mar 17, 2006 | 09:56 AM
BigE's Avatar
BigE
Oh, that helps clear things up. Thanks agian LilSpark.
