Will the pros lend their experience with symptoms of a boost leak?
Old Mar 20, 2006 | 10:53 PM
BB's Avatar
BB
Default RE: Will the pros lend their experience with symptoms of a boost leak?
I had a so called extra puff in the exhaust and the car did not run strong and they found a weak fuel injector. The dealer found a lean reading in one of the cylinders. May not be your problem but just another thought for you. Good luck.
Old Mar 21, 2006 | 11:34 AM
PSI Chick's Avatar
PSI Chick
sounds like you're running directly off the wga. check your vacuum lines, sounds like one is either popped off or has a hole in it.
Old Mar 24, 2006 | 03:15 AM
poolman0617's Avatar
poolman0617
I just wanted to give a big THANK YOU to all of you who gave your advice and input on this problem. I did a leak test last night, found two leaks actually, and took care of them. Seems to be running much better now. I'm not sure if there is some kind of relearning that the ecm will need to do, but either way I can already see a huge improvement. Boost no longer drops down in higher gears so I think she's good to go. Put on a K&N Typhoon that came today and she's sounding sooo beautiful. Thanks to you all!
-Eric
Old Mar 24, 2006 | 10:16 AM
BigE's Avatar
BigE
You very welcome. The computer will adjust after a few drive cycles. Smile BIG!
Old Mar 25, 2006 | 07:34 AM
poolman0617
Thank you [sm=smiley17.gif]
Old Mar 26, 2006 | 01:40 AM
black4's Avatar
black4
out of curiosity where where the boost leaks at?
Old Mar 27, 2006 | 02:32 AM
poolman0617
One was a hole in the rubber piping going into the i/c. The other was a small tear in the rubber housing over the end hard vacuum line. I'm not sure if the second one was causing a problem. It was something I SAW as opposed to heard, and replaced it anyway.
