boost with stage 2
Old May 25, 2004 | 01:19 AM
hotredsrt's Avatar
hotredsrt
Default boost with stage 2
I just orered stage 2 witout the toys I was wondering what kind of boost you get with the toys because I want to know if I can turn my mbc up right now I am getting 15 psi
Old May 25, 2004 | 07:50 AM
71RoadRunner's Avatar
71RoadRunner
Default RE: boost with stage 2
The toys will only up the boost a little from the regular Stage 2 when the 100 octane is used. Otherwise there is no boost difference.
Old May 25, 2004 | 10:26 AM
glhs837's Avatar
glhs837
Actually , you will want to sell your MBC when you get S2. Since S2 maxes out the effciency of the stock turbo, at times seeing up to 20psi, right at the ragged edge of where the turbo is making any usable power, there are no gains to be had using an MBC or EBC. Unless maybe a DSBC helps you launch.
I have not been around too much, been alot of Stage 2 stuff going on over at the SRTforums. But two quick notes for stage 2 owners, just in case you are not on there.
1. ADJUST THE WASTEGATE PROPERLY!!!!!!! NO AGPS ALLOWED OR NEEDED.
2. PERFORM A LEAK CHECK ON YOUR CAR BEFORE INSTALLING STAGE 2.
Old May 25, 2004 | 04:57 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Wasn't that leak check on the intake system....?[&:]
Old May 25, 2004 | 05:44 PM
glhs837's Avatar
glhs837
Yep, actually, it ends up being from the point where the intake pipe ataches to the turbo to the throttle body. The tester attaches to the turbo body itself. I had two leaks, which I tightened, and less than a week later one of those popped completely loose. Just got 5 T-bolt clamps, I'll be installing those over the next few days.
Old May 27, 2004 | 05:49 AM
71RoadRunner
I would hope that it would be leak free already, what causes these leaks?
