MBC
Old Mar 29, 2006 | 11:33 PM
mxrnick's Avatar
mxrnick
Default RE: MBC
and when i remove the green line i dont need to cap the turbo end either?
Old Mar 30, 2006 | 12:12 AM
OrangeBlast99's Avatar
OrangeBlast99
Default RE: MBC
you wont need to cap it because your putting a brand new line where the green one WAS
(which is gonna go from there (turbo) to where the black one comes off on the wastegate)
Old Mar 30, 2006 | 12:28 AM
winniep's Avatar
winniep
Default RE: MBC
Is this how you could route lines for an EBC?
Old Mar 30, 2006 | 12:51 AM
OrangeBlast99
Default RE: MBC
Well...
This isnt really the way you would route lines for a "Boost Controller".
I mean, is this the best way?? Yes I think so. But you could add a MBC, EBC, or In cabin BC any way you want.
What this is doing first most is, its routing your vacuum lines the way a Turbo SHOULD be set up. The stock way, lets the ECU control your boost. So basically, if you hook up a MBC to your stock car, the ECU will eventually say "HEY! WTF! My boost is too high!!", so it will lower it automatically.
This way, that will not happen, because the ECU cannot control the boost now.
This is the way a turbo is set up on most cars as well.
But to answer your question, Yes, you can set up an EBC this way too.
What I should also say is if your running stage 3, you probably dont need to do this, since the ECU for stage 3 will have boost set very high already...
Boost for stage 0/1 is usually set at 15 or below, stage 2 slightly higher, then stage 3 even higher.
Old Mar 30, 2006 | 03:56 AM
mxrnick's Avatar
mxrnick
Default RE: MBC
ok i set it up just like you said and there must be something wrong with my MBC beacause all i get is 4psi max of boost. if i close the MBC then it will boost out of control. why did my MBC come with a T fitting. is there some other way of setting up this type of MBC.
Old Mar 30, 2006 | 01:44 PM
OrangeBlast99
Default RE: MBC
What I would do is take out the MBC and see if your boosting well. If you are, you know its the MBC, if you still arent, then you may be leaking somewhere.
Old Mar 30, 2006 | 03:12 PM
itsnino's Avatar
itsnino
Default RE: MBC
might be a dumb question but i have the toys on my srt4, is the dial-a-boost better than a mbc or can i have both?
Old Mar 30, 2006 | 03:16 PM
OrangeBlast99
Default RE: MBC
It depends.
I dont have toys, but if the dial a boost at FULL Boost is what a normal wastegate would put out, then Yes, you should be able to use a MBC.
But if the dial a boost (at highest setting), raises the boost LIKE a MBC, then i would say there is no need.
If your already boosting about 18-20 psi, then id say you are fine, if your not, then you can probably use a MBC. (Stage 2 though, not a regular stock SRT4)
Old Mar 30, 2006 | 11:13 PM
mxrnick's Avatar
mxrnick
Default RE: MBC
yeah i take the MBC off and it runs great boost at like 14. do you know why the MBC came with a T fitting. here is a link to ebay. this is the exact one i bought. just wondering, did anyone else buy this same MBC or one like it off of ebay?
http://cgi.ebay.com/ebaymotors/TURBO...spagenameZWDVW
thanks for the help though.
Old Mar 31, 2006 | 12:14 AM
OrangeBlast99
Default RE: MBC
dude, not for nothin, it KIND of looks like my turbosmart one, but I am really not sure of how quality that peice is gonna be when its 20 bucks new.
The turbo XS is about 80 bucks, and the Turbosmart is about 60.
I wouldnt use a peice like that in my car. I would go buy a brand name one.
Its probably defective, or just very very cheap.
I had an extra TurboXS one, but sold it to some kid with an 06 STI for 40 bucks.
