so i bought a mbc off of ebay and i set it up inline from the green solenoid to the wastegate and all it does is bleed off boost into the atmosphere. it peeks at like 20 psi and then slowly drops to like 11 psi. my question is is there anything i can do to keep it to hold at like 18 psi? why wont it hold at least at 14 psi like stock. what should i do to get the boost to hold at like 18 psi?
Turn it down a bit, play with it until you get it right. It wont hold 18psi on a stock wga, the stock wga only has a 4lb spring, its not strong enough to hold that. You should at least hold 13-14 maybe slightly less.
